It looks like you’ve got multiple verts on top of each other on the excluded edge. I recommend you try fixing with this:
- Go to vertex selection in Edit Mode and wireframe view
- Box-select all vertices at the bottom of the mesh
- Then go to Vertex > Merge Vertices > By Distance
That should all you to ALT + Select that bottom edge loop.
