Forum Archive › Alt-click does not disable all modifier (2.9) › Reply To: Alt-click does not disable all modifier (2.9)
Sorry I should say you remove the modifier off off 1. then select the others and with the original with no modifiers on it as the “active” then press ctrl L and choose modifiers. it will make the others the same. You add or remove the same way.
