Reply To: Align tool in Blender (AKA Copy transforms) – similar to 3dsmax Align tool?
Forum Archive Align tool in Blender (AKA Copy transforms) – similar to 3dsmax Align tool? Reply To: Align tool in Blender (AKA Copy transforms) – similar to 3dsmax Align tool?
#91447
Dwayne Savage
    As an additional note: If you use the copy attribute addon you may want to change it’s hotkey. I change it to ctrl+c+drag. For most people I’d recommend changing it to alt+c. The reason I say this, is that copying and pasting poses is done a lot in my experience and having to go thru the menu is slower and kind of annoying. Maybe that’s just me. To change it quickly. Ctrl+comma or edit/F4->Preference. Then click keymap. Then click key-binding next to search box. In search box, type “ctrl c” without the quotes. Scroll down until you see pose. Then under that you will see the 2 Ctrl+c options. The Copy Attribute is the one you want.
    -For Alt+C there are 2 ways to change it. Once it’s changed it will disappear since it no longer matches the search.
    • Click where it says Ctrl+C. Then press Alt+C.
    • Expand it then click the alt button first. Then click the ctrl button.
    -For Ctrl+C+Drag: How this works: when you press Ctrl+C it copies the pose. When you hold down ctrl+c and move your mouse you get the Copy attribute menu. Once the menu pops up you can let go of the ctrl+c.
    1. Expand Copy Attribute
    2. Click where it says press and on the drop down select Click Drag.
    3. Scroll down to 3D View and expand Copy Object.
    4.  Change Press to Click.
