Reply To: A Mesh I am using stays Transparent, can’t change it.
Forum Archive A Mesh I am using stays Transparent, can’t change it. Reply To: A Mesh I am using stays Transparent, can’t change it.
#83284
Adrian Bellworthy
    @wrongwright If you  are using the course start file, to see through the walls into the room backface culling has been enabled.
    You probably have flipped normals,
    select the object and enter edit mode, select everything with A, then press SHIFT+N to recalculate the normals.
    If this doesn’t fix it, can you give more info with images or video.
