Reply To: 2:26 – if the mesh hasn’t been unwrapped why does it still show as if it might have been
Forum Archive 2:26 – if the mesh hasn’t been unwrapped why does it still show as if it might have been Reply To: 2:26 – if the mesh hasn’t been unwrapped why does it still show as if it might have been
#82557
Dwayne Savage
    Yes blender has default UV Maps for all primitives. Also blender auto updates the UV Map as you edit the mesh. If you want no UV Maps at all then you need to goto properties editor->mesh tab->UV Maps panel and delete it/them if you’ve added additional. Side note: shader editor uses active UV Map by default. If there isn’t one then blender uses the generated coordinates.
