Forum Archive › 16:52 using the empty object to control the displacement – I can’t move the empty! › Reply To: 16:52 using the empty object to control the displacement – I can’t move the empty!
Hey @erikitect,You can’t click and drag the empty.Click the empty to select it, then click and drag the blue arrow of the move gizmo.
If you don’t use the gizmo’s, you will need to press G to move the selected object.
