Reply To: 16:52 using the empty object to control the displacement – I can’t move the empty!
Forum Archive 16:52 using the empty object to control the displacement – I can’t move the empty! Reply To: 16:52 using the empty object to control the displacement – I can’t move the empty!
#78002
    Another thing could be you locked the move transform in the N panel, but I guess you’d remember that if you did. I think it might be as Martin says. And just in case check if you added any constraints to it.
