Forum Archive › Wouldn’t it be easier and more efficient to simply merge the vertices at center rather than fixing them all manually like this? Is there a reason you wouldn’t want to merge them? › Reply To: Wouldn’t it be easier and more efficient to simply merge the vertices at center rather than fixing them all manually like this? Is there a reason you wouldn’t want to merge them?
If I recall correctly that would misalign the outside corners, but if you try it and it gives a good result, go for it!
