Hi @judisak ,
that is a good question…theoretically, micro displacement might work, but I’m not sure how large you’d have to make your (baked) Texture, in order to be able to get close enough…there might be other problems, that I’m not thinking of at the moment…I’m sure Kent will be able to provide a better and more complete answer later.
You certainly can’t use a Displacement Modifier, becausethe adaptive Sudbivision Surface Modifier has to be the last in stack and first diplacing and then subdividing won’t give you the detail you’d want.
