Reply To: Why my render image look clear then blurry ? thanks
Forum Archive Why my render image look clear then blurry ? thanks Reply To: Why my render image look clear then blurry ? thanks
#43927
Thibaut Bourbon
    Hi @kaderfiren,
    Try tuning down your denoising settings. The rendered tiles that are not yet denoised (the ones that you call “rendering”) are on the edges, you see the denoiser seems to strongly change the final result. Here are the default values, it should reduce the bluriness you are seeing. Maybe increase also the amount of samples to compensate.
