Yes, like Omar says, ‘double Vertices’ are the probable cause. Remember that Clamp Overlap in your other Question; that clamped the Bevel, because of those smae “double Vertices’.
M > Merge > By Distance; (Omar made a little typo there 😉)
(Tip, to Select everything, use the shortcut A, that way you are certain that everything gets Selected.)
