Reply To: Why does the decorative curl from my bezier curve have an uneven thickness (thick at one end, decreasing to very thin on the other)?
Forum Archive Why does the decorative curl from my bezier curve have an uneven thickness (thick at one end, decreasing to very thin on the other)? Reply To: Why does the decorative curl from my bezier curve have an uneven thickness (thick at one end, decreasing to very thin on the other)?
#58625
    I’m relatively new to Blender so the support is very much appreciated!!
    Well welcome to Blender and CG Cookie! The issue in your file is the taper curve object (called BezierCurve.003 in your scene). Currently it’s shaped like the left image when it should be shaped like the right image:
    Here’s the part of the video where I explain this taper curve object.
