Reply To: why does my edge not bevel the same way?
Forum Archive why does my edge not bevel the same way? Reply To: why does my edge not bevel the same way?
#93218
    Yes, like Danny said, it is most likely a matter of so-called ‘double Vertices’.
    The Shortcut is M > Merge > By Distance (it’s faster than going into the Menu and you’ll be using it a lot , so it’s worth learning the shortcut). And to be clear, you need to do that before pulling those Edges up.
