Reply To: Why do you use “mesh from curve/meta/surf/text”, instead of applying the subdivision please?
Forum Archive Why do you use “mesh from curve/meta/surf/text”, instead of applying the subdivision please? Reply To: Why do you use “mesh from curve/meta/surf/text”, instead of applying the subdivision please?
#71397
    a hidden option somewhere that does this more intuitively
    Not that I know…
    There does exist an Addon called Modifier Tools that has a button to Apply all Modifier on selected Objects, but that won’t work when you have linked copies… The Convert to Mesh has no problem with that situation 🙂
    It is one of those things I use so much and the Convert to … are a bit ‘hidden’ in submenus, that I have them in my Quick Favorites and that way, even with only one Object and one Modifier, it is usually the fastest way to get the Modifier Applied, especially when  I don’t have the Modifier panel open…
