Reply To: Why do we need an alpha channel in the saved normal map?
Forum Archive Why do we need an alpha channel in the saved normal map? Reply To: Why do we need an alpha channel in the saved normal map?
#24938
    Since this normal map bake in the demonstration is only one of the stones, later we need to layer the different stone textures together into a consolidated texture map. The alpha channel makes that process easier, so we don’t have to cut out for the other stones’ UV islands.
    But ultimately, the final normal texture map won’t need an alpha channel.
