Reply To: Where should I go next?
Forum Archive Where should I go next? Reply To: Where should I go next?
#83840
Wayne Dixon
    Hey Thorpie,
    I would recommend doing the body mechanics course and then applying that to any animations you want to plan for your own further development.
    In that course you will learn the workflow (Plan, Block, Spline, Polish) which is what you will do on every animation you will do.
    You will also learn about video reference which can be so helpful as a tool.  If you want to do a different walk cycle with a different character, you can!
    Just film your reference, pick out your key poses, plan it, block, spline, polish.
    You can even do the character ball assignment again too if you like.   You are in control of your learning 😉
    If that’s what you want to do – then I say do it!
    We are here to guide you – but you’re in charge.
