Reply To: When i add the Empty my whole array goes crazy
Forum Archive When i add the Empty my whole array goes crazy Reply To: When i add the Empty my whole array goes crazy
#28296
chelly26
    I am currently using the Blender 2.8 version.
    I had the same issue.  Here is how i solved the problem.
    1-I started with a simple cube, just to keep things simple
    2- Selected the cube, entered in edit mode, selected all elements (vertices+edges) with the A-key and displaced them all at once.
    ( you’ll notice while performing the displacement that the origin point remains a the same position, just keep going it is part of the plan)
    3- Got back in object mode, created an “empty”,  and made sure the empty was at the SAME position with the origin point of the cube.
    4- Added the “array” modifier to the cube (here was my settings)
    6- In addition to the position, I made sure the empty and the cube had the same SCALE (it made the difference for me).
    7- I selected the empty and performed a rotation with respect to the z-axis.
    I hope my answer will help you. Good luck!
