Forum Archive › What’s the difference between using the Factor node and Color? › Reply To: What’s the difference between using the Factor node and Color?
Wow, thanks for the fast & thorough reply!
So if i get you right, if you would want to use the colourramp as a factor for a mix shader, you should use the Aplha (grey node) to lock it into the Factorslot of the Mixnode.
