By all means Kent, have at it! If anything, you’re the one who gave me the idea when I thought back to you mentioning that vectors could be thought of as color data. Just glad that it worked out. I’m a bit curious if you had any artifacts and if so how you dealt with them? I went back and ended up clamping the RGB values before they got to the emit node. The results were clean and the two outputs looked more or less identical but I couldn’t be sure. In any case, glad I could contribute to this!
