Reply To: What's the advantage of using the auto smooth in the mesh data over an edge split modifier?
Forum Archive What's the advantage of using the auto smooth in the mesh data over an edge split modifier? Reply To: What's the advantage of using the auto smooth in the mesh data over an edge split modifier?
#24694
Charles Ocheret
    I think I’ve figured this out on my own. If you have no other modifiers (e.g. subdivision surfaces) then auto smooth seems like it might be more efficient. However, if you are using modifiers, you should use an edge split modifier to achieve the same effect. However, the auto smooth feature looks like it does not export properly (at least to most formats I’ve tried). Whereas the effect of the edge split modifier does.
