Reply To: What would be the equivalent to the “Sculpt/Peak” tool you’re using in 4.3?
Forum Archive What would be the equivalent to the “Sculpt/Peak” tool you’re using in 4.3? Reply To: What would be the equivalent to the “Sculpt/Peak” tool you’re using in 4.3?
#95561
    If you sculpted the shape and ran out of undo’s, best thing to do is either start over and sculpt again or simplify the shape with the smooth brush. Kent always pinches the corners with the pinch brush to get a sharper edge. You see him doing it and you think ah perfect, looks easy, then you go and try it and you end up with a mushy mess. So it takes practice.
