Reply To: What should I do if Blender does not repeat my last used inset/bevel settings? Is there any way to change this in the preferences?
Forum Archive What should I do if Blender does not repeat my last used inset/bevel settings? Is there any way to change this in the preferences? Reply To: What should I do if Blender does not repeat my last used inset/bevel settings? Is there any way to change this in the preferences?
#27310
Jonathan Lampel
    Hey Kavern, I found out after recording that it only saves the settings if you tweak them manually after confirming. Try insetting or beveling and then adjust the amount after from the toolbar or F6 menu. That should do it!
