Reply To: What is the difference between shader, materials and textures?
Forum Archive What is the difference between shader, materials and textures? Reply To: What is the difference between shader, materials and textures?
#83486
    “Just wondering, “building a shader”, does that mean there are different types of shaders..”
    That is one of those times, when the term Shader is used for Material 😉
    And something that is really rare…Dwayne is slightly wrong with:
    “For mapping: Blender by default uses UV Map coordinates. If there isn’t a UV Map then it uses Generate.”
    Image Texture Nodes in Blender use UV Coordinates by default..if there is no UV Map, it will display a solid color!
    Procedural Texture Nodes use Generated Coordinates by default (with the exception of the White Noise Texture, that needs explicit Texture Coordinates).
