Reply To: What is the difference between LoopTools → Flatten and scaling an axis to 0 (X/Y/Z = 0)?
Forum Archive What is the difference between LoopTools → Flatten and scaling an axis to 0 (X/Y/Z = 0)? Reply To: What is the difference between LoopTools → Flatten and scaling an axis to 0 (X/Y/Z = 0)?
#99240
    Hi Deb,
    Loop Tools ‘averages out’ the Normals and is okay and fast, when your not using a specific Axis. (You disabled the Z- Axis, while usib=ng Best Fit, that obviously didn’t work as you expected).
    Scaling to 0 gives you more control, because you can control both the Pivot Point and the direction of the resulting Face (using Custom Normals, if needed).
