Reply To: What is the best way to do a retopo of another mesh with the same faces?
Forum Archive What is the best way to do a retopo of another mesh with the same faces? Reply To: What is the best way to do a retopo of another mesh with the same faces?
#81156
    Yes as Adrian says, you don’t need to do anything if what you are after is two objects with the same data, you just need to duplicate it and there you go.
    If you say that because one object has stuff on top like modifiers, then you just need to swap the object data. First select the mesh you want its data to be changed, then select the mesh that has the data you like, Control + L and Link object data.
