Reply To: What is the best method for unwrapping this hair and applying a texture after if course converting to a mesh object?
Forum Archive What is the best method for unwrapping this hair and applying a texture after if course converting to a mesh object? Reply To: What is the best method for unwrapping this hair and applying a texture after if course converting to a mesh object?
#27301
    Since they’re all tubes, I would cut a seam down the length of the tube for a simple unwrap. Then you could copy the UV’s of that mesh tube to all mesh tubes that share the same geometry (which they all should unless you altered the curve’s settings before converting to mesh).
