Reply To: What is difference between detaching by pressing Y and P ? im beginners and got confused
Forum Archive What is difference between detaching by pressing Y and P ? im beginners and got confused Reply To: What is difference between detaching by pressing Y and P ? im beginners and got confused
#52006
tanya
    This won’t be the best explanation, but here goes.  When you press P you create a new mesh object,  when you press Y it is still part of the original object.  The easiest way to see it is to try it yourself,
    create a cube
    go into edit, subdivide the cube
    on one section use P and another use Y,  you can no longer modify the P one, but you can the Y one
    go into object mode, move and scale the P one and nothing happens to the Y
    also look in the outliner tab area, the P created a new object and the Y doesn’t.
    Hope this helped.
