Forum Archive › What causes this weird clavicle cut? › Reply To: What causes this weird clavicle cut?
It looks like you have flipped normals. Every face has an inside and an outside, you get some wired things happening if you have faces inside out.
In edit mode select all the faces with A, then press SHIFT + N to recalculate the normal direction.
