Reply To: Weird edges along bevels
Forum Archive Weird edges along bevels Reply To: Weird edges along bevels
#95062
    The first one is likely to be duplicated vertices, looks like they are bunching up the bevel. So try to select everything in edit mode and M to merge by distance, see if that helps. The second one is ok, nothing wrong with it, it’s how a bevel in a corner would look. Maybe what’s bothering you is that it has a triangle on top, but may go away if you add another segment in the bevel.
