Reply To: Weight Painting with 4.3 and newer
Forum Archive Weight Painting with 4.3 and newer Reply To: Weight Painting with 4.3 and newer
#95710
Grady Pruitt
    The problem with doing the CTRL was that it wasn’t removing it from the active group. So the bit where you’d remove the darker blue so it would remove it from the active group wouldn’t work.. .  it would just stay dark blue and not turn black. 😀
    To make this easier, I figured out how to duplicate the “Paint” brush and set the mix mode for that one to subtract and labeled both so I knew which one was which 😀
