Reply To: Voronoi texture mapping error
Forum Archive Voronoi texture mapping error Reply To: Voronoi texture mapping error
#74232
    Forget what I said before; I found what the problem is.
    The way the Iris is modeled is (simplified to the part that matters here) something like this:
    Now, if you Scale the Voronoi Texture in Y, that will only affect the inner part, because the outer ‘ring’ is already ‘scaled  0’. I hope that makes sense to you.
    This also happens when Kent does this, but the flat outer part is hidden behind the Sclera.
