Reply To: Vertex Bevel / Edge bevel
Forum Archive Vertex Bevel / Edge bevel Reply To: Vertex Bevel / Edge bevel
#100407
    Hi Kazim @kazim ,
    That’s probably the Clamp Overlap kicking in. With such a large Vertex Bevel as you have, the Edge Bevel doesn’t have much room left.
    Remember, that what Clamp Overlap does, is that as soon as two Vertices ‘touch’, anywhere in the Modell, before they ‘cross over’, the Modifier stops Beveling. Also, with Modifiers the order matters! Think of what the first Modifier does, then consider what the second Modifier does with the Modified Mesh.
    Please read carefully through the other questions and answers under this Lesson; at least 2 of them are very much related to this.
