Reply To: Vector math node has no value output.
Forum Archive Vector math node has no value output. Reply To: Vector math node has no value output.
#53161
    Hey Morten, Math > Absolute hasn’t changed.
    I was lazy and just downloaded the zip file and loaded it up in 2.83 and it worked.
    As for the Absolute, the only place he used that is in the ‘Symmetry’ those separate xyz and combine xyz with the adsolute nodes in between can now be exchanged for one node: the Vector Math > Absolute.
    At what point in the video do problems start for you?
