Reply To: UV mysteries! < additional characters to reach the title minimum ; ) >
Forum Archive UV mysteries! < additional characters to reach the title minimum ; ) > Reply To: UV mysteries! < additional characters to reach the title minimum ; ) >
#68410
Mark Smith
    it appears part of the problem is that instead of one vertex at the pole you have 36 or so…
    if you remove doubles or weld the 36 down to one I believe you will achieve your desired result…
    hope this helps
