Reply To: UV mapping issue! Help
Forum Archive UV mapping issue! Help Reply To: UV mapping issue! Help
#84471
Adrian Bellworthy
    The label looks flat, right?
    Your UV’s need to be flat just like the label.
    As Omar said, you need to make a vertical cut, just like the label has.
    The label is not a cylindrical shape, it has the vertical cut to make it lay flat.
