Hi Josh,
The UV map image is embedded in Blender.
When you connect the Image Texture node to the Base Color and click “New,” you need to change the Generated Type from Blank to Color Grid.
In the first video in Chapter 7 (at 2:11), it looks like Ewa’s Blender defaults to Color Grid—at least she doesn’t change anything. I also looked through the course files before checking Ewa’s settings more closely. I’m guessing this is simply because we’re using different Blender versions.
I’ve attached a picture and hope this helps.
