Thanks Jonathan for the reply. While I mentioned adding a separate material for each item, I was only referring to doing that within Blender. By assigning a different material and exporting the FBX of all parts into Substance Painter, SP see’s the separate materials as simply loose parts of the same texture space which would/should allow me to use a single texture image for all meshes within the same FBX. By separating all the meshes by material (loose parts) would/should make it smoother to run in Substance because you can solo each piece by loose part.
Thanks,
Jesse
