Reply To: Using a bevel with 3 segments, leveling the bottom of top half of lock, and modeling order (about 9:10) in vid
Forum Archive Using a bevel with 3 segments, leveling the bottom of top half of lock, and modeling order (about 9:10) in vid Reply To: Using a bevel with 3 segments, leveling the bottom of top half of lock, and modeling order (about 9:10) in vid
#60713
    To your last question: you can use the Active Element as Pivot Point when leveling the bottom, that way you can for instance make the lowest Vertex active. But I don’t know if that helps here…do not completely understand your question to be honest…I’d make sure all my geometry is correct before bevelling and not: bevel and then try to fix the geometry…
