Reply To: Unwrap multiple objects into one UV map
Forum Archive Unwrap multiple objects into one UV map Reply To: Unwrap multiple objects into one UV map
#41145
Thibaut Bourbon
    @tomtomh5 It is possible yes, there’s a free addon that you will find helpful, called Texture Atlas, it’s in Blender’s defaults.
    Once activated you will see a new section “Texture Atlas” in the render tab of the property panel:
    Press the “+” button to create a new atlas, select the object you wish to unwrap together and press “addSelected”. Then you have two choices:
    -Auto Unwrap, and you are basically done
    -StartManualUnwrap: it will join all your objects together, and then you switch to edit mode to unwrap each of them. Once you’re done you press FinishManualUnwrap to restore each object. Note that when it joins the objects the modifiers are temporarily removed, they are restored after.
    Hope that helps!
