Reply To: Unassign Hotkey
Forum Archive Unassign Hotkey Reply To: Unassign Hotkey
#74676
    Hi @halleykc ,
    I am not sure if I understand you correctly, but Selecting with the LMB is dependent on the Mode…When you are in Object Mode, you can select Objects with your LMB, but when you, for instance, select the default Cube, and then switch to Edit Mode (TAB hotkey), you can select Vertices (or Edges, or Faces) with your LMB:
    Does this help, or do you need more/other information?
