Reply To: Unable to reproduce results with Principled BSDF
Forum Archive Unable to reproduce results with Principled BSDF Reply To: Unable to reproduce results with Principled BSDF
#58661
    Well, if this is to learn, then great!
    Practically, when you want fast and easy PBR, then the Principled Shader is often the way to go, but you lose a bit of control..
    Just for educational  fun, here are a few renders; from left to right: your Node setup, Kent’s Node setup and finally mine:
    You seem to lose some definition (shape information) in the dark areas, they become a bit ‘muddy’. Overall it looks a bit more flat (less highlights in the orange and green).
    But still a great effort! (You did forget to connect the Normal Map to the Diffuse Shader…I connected that in this render..)
