Reply To: Trouble with using snapping to vertices holdin control
Forum Archive Trouble with using snapping to vertices holdin control Reply To: Trouble with using snapping to vertices holdin control
#92157
Dwayne Savage
    Just Side note: If you have snapping turned on(Blue Magnet on default color theme) then while you hold ctrl down during transform(Move, rotate, scale) it turns off the snapping. If snapping is turned off(Toggle on/off with shift+tab) then while you hold ctrl during transform it turns snapping on. Also ctrl+shift+tab is a quick way to change snapping setting.
