Reply To: Trouble with Parenting
Forum Archive Trouble with Parenting Reply To: Trouble with Parenting
#86745
Wayne Dixon
    HI Wrongy,
    I’m not sure exactly what you are having problems with.  In the file I can just see 3 bones.  (Root, Root.001 and Root.002)
    It looks like you are at an early stage of following along with the tutorial.
    I would suggest that you try to make it all the way through, and then reassess if you’re having issues.
    Trust the process – follow along as best you can and if you make any mistakes at the end, we can diagnose at which point it went wrong.  (or Wrong Wright if you will)
    At this stage it’s almost the blank starting file.
    Keep going!  You got this.
    (and if you don’t got this – we got you….so technically there’s no way you don’t got this!)
