Reply To: Trouble at smaller scales–advice?
Forum Archive Trouble at smaller scales–advice? Reply To: Trouble at smaller scales–advice?
#58791
    Ahh I see, sorry to hear that. The values I use in the shader do depend on the scale of the object matching the default UV sphere. So if you’re not starting the same way you’ll have to figure out values relative to your object.
    Alternatively you could start from the source file, scale that eye to match your sculpt, and modifier the shader as desired.
