Reply To: Transparency in Ring Shader
Forum Archive Transparency in Ring Shader Reply To: Transparency in Ring Shader
#79373
    Hi @Tyrefryer – simply move the Base Color input into the Alpha socket at the bottom of the Principled BSDF. The black areas of the ring texture will be transparent while the white are opaque. Then you can use the base color swatch to pick a color for your ring.
