Reply To: transmission behave weird
Forum Archive transmission behave weird Reply To: transmission behave weird
#76995
    The only thing I can think of is the placement of your geometry in that second eye that is not showing through. Maybe move it a little bit back and forth and see if it works? Also Go into edit mode, check that your normals are not all backwards and in red with the overlays and shift + N to recalculate. Maybe you have double faces in there and that is why the light is not going through?
