Reply To: This is so confusing! (Displacement inquiry)
Forum Archive This is so confusing! (Displacement inquiry) Reply To: This is so confusing! (Displacement inquiry)
#84229
    You are getting real displacement already, now it’s a matter of dialing it to what you need, see what works for you. The values will also depend on the scale, so be sure the scale is applied. Also if you’re not on the CG Cookie Discord, you can join up, it’s up there in the menu to the left with the tree lines and magnifying glass.
