Reply To: The Gray Back ground Issue NEEDS a solution
Forum Archive The Gray Back ground Issue NEEDS a solution Reply To: The Gray Back ground Issue NEEDS a solution
#26238
    To your point, preemptively, when you create an image in the UV/Image Editor for baking the texture, you can be sure to check the “alpha” option (should be checked by default) and the bake will preserve the alpha.
