Thank you, I just tried every way to set the material and it still didnt work. After a lot of just trying out stuff I changed the “Mesh to Points” Node back to Vertices instead of Corners. Then only 50% of the mesh was black and the other half had the texture working. But after making the scatter node tree in a different geometry nodes network it worked. I still do not understand why it wasnt working the other way but it works now.
