Reply To: Switching from Edit mode TO Object mode causes massive lag.
Forum Archive Switching from Edit mode TO Object mode causes massive lag. Reply To: Switching from Edit mode TO Object mode causes massive lag.
#83261
Adrian Bellworthy
    I’m sorry too, I have to agree with Spikey.
    Check out the Blender requirements, how does your laptop compare?
    The minimum requirements will be enough for basic poly modeling, larger scenes and more complex modeling (like Booleans) will require a machine much closer to the recommended.
    My build matches the recommended, but it can still be a little sluggish with several Booleans in the stack and large scenes.
    Personally, I think the recommended should be the minimum.
    The current minimum is ok for absolute beginners, but once you get further into learning what Blender can do, the minimum just won’t cut it.
